The TD has the clickers right? I believe so....I'm about your same weight and played with my setup a bit before getting it how I liked it. I have it set up for boondocking and general goofing around, and do a little jumping/drops but nothing huge.
- RTS spring set for my weight as per manual
- RTS remote-reservoir 4 or 5 clicks out from full soft
- FTS about 1" threads showing (this will handle poorly on corners on the road/trail - if you don't like that, loosen a little at a time until it gets where you want it)
- Front ski shock spring - with the skis off the ground, loosen the springs until you can rattle the spring/cup around slightly - then tighten them a few turns from there. They are pretty stiff springs for a boondocking setup
- Front ski shock remote reservoirs - 4 clicks from full soft
I am quite happy with that. I think a lot of people are trying to use the remote reservoir "clickers" to do all their suspension tuning, when the springs are a huge part of it.
