How airtight should a turbo be?
JACKAL
37
5
8
Wenatchee
I am new to the Turbo thing and am not sure how airtight you can get the system. I get a few bubbles of air coming out of the turbo to pipe doughnut, it will hold 10 pounds but leaks down to under 5 over a coupe of minutes. Should I replace the doughnut or is this about as good as you can get have less then 200 miles on this one.
Thanks
Spaarky
3,429
1,345
Chester, SD
Silicone the connections. You can use a lot of products... I like to use Yammabond 6B.
As many springs as possible. If that doesn't work, you can use a bolt together connector like OVS, or Turbo Performace
T
TurboMatt
857
251
Thanks
This is fine.
