R
Im finishing a build on a 99 chasis with a 800 xcr in it, I am trying to fiqure out what i need for cluthing and gearing. Ive had the sled for 3 years and cant get it to pull very hard. Here are some spec and things ive done. The motor was rebuild last year, new pistons, gaskets, exhaust valves and cups, i put new v-force 3 reeds in it and running SLP pipes. I was told the motor has motor had the SLP porting. I had one of the carb slides brake and have rebulit them with the new upgraded slides. It has a 163 track, and a TSS98 secondary clutch. I cant remeber the primary weights but it has a newer cluthc and a new square white spring. I can look and get the weight size and info on the secondary. I was told last year that the current gear ratio was way high and should go to a lower ratio. I will have to look and see what gears are on it, I did count them last year and have it written on the side of the cover. Any help would be great.
