Here's the newest install video for the Silber turbo kit on a Polaris Pro RMK
https://www.youtube.com/watch?v=9E0VC824dv0
it really helps with intalling a newer kit running the BullyDog two injector
kit its kinda long but worth the watch
Thanks Silber ( a little slow to deliver but you came through :face-icon-small-win)
i helped on one of these and a few things i noticed
make sure everything is ziptied and best routed protective covering on rub points
i recomend removing the throttle body boot when drilling the hole then you can inspect your reeds
use some kind of lube on Orings on injectors and billet boot and fuel filter
change out fuel filter if used check clutch for wear when apart rollers,bushing etc.
clean as you go i found dirt and grime in the air intake in the hood from trailering
now get after it !
now get after it !
