B
I have a 91 Phazer II with Mikuni Round Slide 38mm Carbs. I have a couple of questions:
- I just cleaned both the carbs and am trying to set the idle speed. What is the best process to use for setting the idle speed?
- I have the Idle RPM I want but I am certain that one carb is set differently then the other.
- Can you turn the Idle Mixture Screw in to far to the point that it interferes with the slide.
