17' Axys RMK Pro 155" w/ Silber @ 5psi. Installed the kit on a brand new sled...made sure to get a couple good heat cycles on the belt. I also washed the belt in warm soapy water, and also cleaned the clutch faces before the first ride.
At 50 miles, I blew the OEM belt. I felt it going and got stopped in time before it grenaded. I noticed after a decent pull ~5+ seconds WOT, I'd stop and feel the clutches, the primary was extremely hot, like, too hot to leave your hand on the clutch.
I'm running the supplied 76g weights, blew the belt at around 5'k. Max RPMs I saw was 8350.
I replaced the belt with the Gates Carbon (45c4553), and went up 2 grams to see if it would lower belt temps...but the clutch is still getting hot on WOT pulls! WTF?!
Also, the pic below is of my OEM belt, with LESS THAN 50 miles:
