Upgrade to Premium
Reply
  #1
Old 02-26-2013, 05:26 PM
sledheadjake sledheadjake is online now
Currently: playing with my ditch pickle
sledheadjake has a reputation beyond reputesledheadjake has a reputation beyond reputesledheadjake has a reputation beyond reputesledheadjake has a reputation beyond reputesledheadjake has a reputation beyond reputesledheadjake has a reputation beyond reputesledheadjake has a reputation beyond reputesledheadjake has a reputation beyond reputesledheadjake has a reputation beyond reputesledheadjake has a reputation beyond reputesledheadjake has a reputation beyond repute
Garage
Default ROLL OVER VALVE ?
Do these sleds need one if you leave the intake set up stock?I have been looking at evolutions parts site and they say that one is needed if you switch to a cold air intake,I am also not able to find where on their site that they sell their cold air intake Thanks
Jacob
Rate this post: Yes | No
  #2
Old 02-26-2013, 06:27 PM
MTN_VIPER's Avatar
MTN_VIPER MTN_VIPER is online now
Currently: Making roll-over valve kits since 2008
MTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond repute
Default
Jacob,
I still recommend them when using the stock intake. What can happen is oil drains in to the stock air filter and oil soaks it. If the sled is still running while its on its side, the oil can run out at a much faster rate due to the breather air flow exiting the hose. Then the excess oil drips out of the filter and makes a mess.
Bill
__________________
Four Stroke Solutions LLC
Patented Roll-Over Valve Systems
ROV kits for M/XF7000/Viper, Sidewinder and King Cat with Quick-prime!
For Arctic Cat and Yamaha Sleds
Patents 8,225,766 8,528,516 9,303,537
http://fourstrokesolutionsllc.webs.com/
e-mail fourstrokesolutionsllc@hotmail.com
The Following User Says Thank You to MTN_VIPER For This Useful Post:
sledheadjake (02-26-2013)
  #3
Old 02-26-2013, 06:49 PM
Garage
Default
^^^^ What is the ROVCM option?
  #4
Old 02-26-2013, 07:19 PM
JustBoostIt's Avatar
JustBoostIt JustBoostIt is offline
Currently: Enjoying the builds
JustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond reputeJustBoostIt has a reputation beyond repute
Default
The Evo cold air intake is an under the hood silicone piece called a vfl. Replaces the stock air filter and all the poorly fitting plastic
__________________
Evolution Powersports Canadian Distributor
We stock all Evo parts in Canada and reflash on site
Evo Sidewinder Stage 5 and Stage 6 Big Chute kits coming soon!
Evo Sidewinder relashes and Maptuner options in stock
Evo Sidewinder boost hoses, BOVs, CAIs, and I/C grills in stock
Stereo sleds….Yup that's us!
1100t Single and VmAp ECU mountain reflashes!
Dealer and customer inquires welcome to gene@allgo.ca
The Following User Says Thank You to JustBoostIt For This Useful Post:
  #5
Old 02-26-2013, 08:45 PM
Garage
Default
I have looked all over evolutions site for the cold air intake and can not find it, am I missing something here?
  #6
Old 02-26-2013, 08:57 PM
RACINSTATION's Avatar
RACINSTATION RACINSTATION is online now
Currently: Working on 2018 Proclimb mods
RACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond repute
Default
It is on the site. We have them in stock if you need. I would not ride a four stroke without the rollover valve. It is mandatory.
__________________
The Racin Station
60 South 1st Street Driggs, Idaho 83422
Ph: 208-354-2777 E-Mail: racinstation@hotmail.com
The Racin Station is your TURBO MOD HEADQUARTERS
for Arctic Cat Proclimb 8000/1100 and Yamaha Vipers and Sidewinders!
TIMBERSLED FULL LINE DEALER!!!
Proclimb Carbon Fiber Vents
Your MDS weight headquarters
Team ProClimb secondary complete setups ready!
Reman M6,M7,M8 and M1000 cylinders in stock.
Jaws M8 Singles for the 2012-2017 in stock!
Jacobsen Rollover valves in stock for M1100Turbo and Viper/M7000!!
Camoplast 3" and 3.2" 174, 162 and 156 x15 tracks on hand now
The Following User Says Thank You to RACINSTATION For This Useful Post:
  #7
Old 02-26-2013, 11:19 PM
MTN_VIPER's Avatar
Default
Quote:
The electronic roll over valve control module (ROVCM) has 2 primary features.
The standard method of controlling the shut-off valve is to use straight battery voltage. When using battery voltage (approx 12.3 to 12.7 volts) the Roll-Over valve current draw is approx 550 milliamps.
The ROVCM has a variable pulse width modulation or variable voltage output. For example it takes more electrical energy to close the valve then it does to keep it closed. The ROVCM takes advantage of this by commanding a higher voltage output (approx 15.5 to 15.7 volts) to close the valve. Once the valve is closed the ROVCM backs off the power output to approx 8.5 volts, (the valve will stay closed all the way down to 6 volts) at the same time this also reduces the current draw to approx 350 milliamps.
Because the shut-off valve closing strength is increased by approx 140%, it is much more resistant to the oil vapor/moisture sludge build up that can occur in breather hoses over time. The faster/stronger closing power allows the valve to better contain any remaining oil that may stiil be in the breather hose from previous roll-over events. The stronger closing power also provides more consistent valve performance in extreme cold, where everything seems to move just a little bit slower!
Additionally the higher closing voltage allows for greater flexibility in relation to how the valve is mounted. This can come in handy in certain custom applications where it’s a little more difficult to mount the valve with the solenoid end angled upwards.
Also because the valve is effectively 140% stronger, the valve doesn’t require cleaning as often reducing ROV system maintenance!
Depending on battery size and condition, the reduced current draw during the “closed mode” allows the roll-over valve to stay closed for longer periods of time. (if needed)
The lower operating voltage during “closed mode” also reduces the valve solenoid coil operating temperature and helps promote longer valve life. Reduced current draw is also well suited to smaller light weight batteries that have less amp hour ratings.
The other main feature of the ROVCM is the battery voltage monitoring/auto shut down mode. The ROVCM contains a micro-controller that monitors the sleds battery voltage.
There is an internal timer programmed inside the ROVCM. After the ROVCM detects that the ROV system has been on for 2 hours constantly, the ROVCM enters battery voltage monitoring mode. If the sleds battery voltage drops to approx 12.1 volts (lead/acid battery) or 13.2 volts (lithium battery), the ROVCM will automatically shut down the roll-over valve. This helps prevents draining/damaging the battery from leaving the roll-over valve on by mistake. (pulling the tether cord, but forgetting to turn off the key)
Bill
__________________
sledheadjake (02-27-2013)
  #8
Old 02-27-2013, 12:26 PM
Bendy Bendy is offline
Currently: Dooin the Snowdance
Bendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond repute
Default Fourstrokesolutions
Nice fit and finish! Although I didn't go with the premium model with the module, its still great. Chances are if you ride hard and push the limits, you NEED one! Thanks Bill, for designing and producing a great product. These sleds should have them from factory.
The Following User Says Thank You to Bendy For This Useful Post:
MTN_VIPER (02-27-2013)
  #9
Old 02-27-2013, 03:33 PM
dejadoo's Avatar
dejadoo dejadoo is offline
Currently: Not set.
dejadoo has a reputation beyond reputedejadoo has a reputation beyond reputedejadoo has a reputation beyond reputedejadoo has a reputation beyond reputedejadoo has a reputation beyond reputedejadoo has a reputation beyond reputedejadoo has a reputation beyond reputedejadoo has a reputation beyond reputedejadoo has a reputation beyond reputedejadoo has a reputation beyond reputedejadoo has a reputation beyond repute
Default
Quote:
Originally Posted by MTN_VIPER View Post
Jacob,
Bill
been there, done that, upside down anyway
  #10
Old 02-27-2013, 03:41 PM
Sage Crusher's Avatar
Sage Crusher Sage Crusher is offline
Currently: Tuning the K-MOD....
Sage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond repute
Default
Bill Stands behind what he sells- and is super fast to get it to ya
S/C
The Following 2 Users Say Thank You to Sage Crusher For This Useful Post:
MTN_VIPER (02-27-2013), sledheadjake (02-27-2013)
  #11
Old 02-28-2013, 12:00 AM
mkinak mkinak is offline
Currently: M1100T
Basic Member
mkinak has a reputation beyond reputemkinak has a reputation beyond reputemkinak has a reputation beyond reputemkinak has a reputation beyond reputemkinak has a reputation beyond reputemkinak has a reputation beyond reputemkinak has a reputation beyond reputemkinak has a reputation beyond reputemkinak has a reputation beyond reputemkinak has a reputation beyond reputemkinak has a reputation beyond repute
Click Here to Register
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Roll Over Valve Issues Thread Starter — TheYamMan Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 6 Last Post — 02-11-2013 07:49 PM
Thread — ROLL OVER VALVE OPEN END need Help Thread Starter — newfiem8sno-pro Forum — Arctic Cat: 1100 ProClimb Replies — 8 Last Post — 01-29-2013 11:35 AM
Thread — OFT Roll Over Valve Thread Starter — Sledingtime Forum — Yamaha Replies — 5 Last Post — 12-21-2011 10:18 PM
Thread — Roll Over Valve & Tether Thread Starter — clatla Forum — Yamaha: 4-Stroke Replies — 10 Last Post — 02-21-2011 12:54 AM
Thread — Jacobson roll over valve Thread Starter — robb Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 27 Last Post — 11-29-2010 12:09 AM
