throttle/oil pump settings?
ullose272
3,372
963
boise idaho
how far should the oil pump open when the throttle is wide open? when mine is wide open my oil pump arm can open ALOT more
Kraven
1,462
555
MIDWEST
I would be more concerned with fuel/oil ratio than anything else. My 2002 EDGE-X 800 HAD "more room to move" on the pump arm as well @ full throttle.
My 2007 D-7 had the "marks"lined up on the pump was overly rich @ 37:1, 1 1/4 to 1 1/2 turns on the 10mm adjuster nuts and I've been running @ 57:1 for the last 1200+ miles.
I'm more that comfortable with 55:1 or 60:1
O
Sep 30, 2009
84
9
8
I tend to go another way about it, since there is so much in-consistancy with the in the cables and marking on the pumps.
Sleds should run 40:1 to 50:1 on average (I have gone as far as 65:1) fuel:eek:il ratio
40:1 is equel to 40 gallons of gas to 1 gallon of oil OR 10 gallons of gas to 1 quart of oil.
If you are richer than that (1 quart to 7 gallons), start there and lean it out a little at a time till you get to the 40-50:1
Seems as if whenever I adjusted to the alignment marks that I ended up way rich.
