Note: this_feature_currently_may_not_be_available_in_some_browsers
I would like to run a different skid either a Cat or Poo, but the mounting I think would be hard to figure out, with out having the sled the skid came out of. To bad there isn't a template to run a Cat skid.
I would use the Polaris 136 Xtra lite. You can use the front mounting holes and build your own rear hangers. I have an extra one if you want to buy it.
Did you use the stock mounting holes? Is the mounting bolt distance the same?
-BD1
I just rode my 2000 mountain max with an 06 159" polaris skid for the first time and it is awesome! If you are debating swapping out your yamaha suspension for a polaris skid, do it! Not only is the polaris suspension lighter, it also transfers a lot more, softer ride, and makes the sled a lot easier to handle on the mountain.
i have those dimensions written down somewhere for an 06 cat 153 into a mnt max if your interested.
Hey, have you ever tried adjustable control rods? I've been debating on that or the mpi transfer kit. Does it still give a good ride on the trail?
