Is there anyone building this in a kit I can buy? I guess The spacer basically, really everything else I can get on my own right? just pistons and some machine work.
Note: this_feature_currently_may_not_be_available_in_some_browsers
As far as actual dyno sheets, I have no idea. The guy that made our port templates says they could be made to handle ~200 hp @ sea level.
I wouldn't say we're getting that much, we keep our porting pretty mild, but it feels stronger than our thundercats ever did.
My dad and I are running 3 of these as twins, and we've just got single pipes, reeds, and heads on them. They are a vast improvement over a stock 900. The bottom and mid on ours is much better, but like I said, mild porting.
We ran 1 for over 1500 miles this season, with no motor problems and no touching of the motor after the initial tune (we broke a chain.) We had some detonation problems with the other two, so we backed off the compression a little. (running 91 octane in them all)
Our best running one will keep up with an M1000. Same rider/conditions, they are very close, probably too close to call. The M1000 had reeds, single pipe and head also, and I would say it was running well.
The 975 has a much harder hit, like the 900 twin is known for over the M1000.
Short answer, I think it is well worth it, especially if you don't particularly care for the ergonomics of the M-series.
Ted at Terra-Alps sells this as a kit. The spacer shims up the cylinders to account for the pistons from the M1000 being taller than the stock 900's.
You can also just stack 5 base gaskets to shim the cylinders, we did this with one and ran it for a couple months with no problems before we got our shims made.
If you do this, I would highly recommend the recoil adapter for the M1000 recoil as well.
