I've got a buddy that has an older v-max with a 136 inch track and small lugs. He wants to put on a 136 with two inch lugs. Will any 136 inch track work?
All 136" tracks should be 2.52 pitch. As long as the lugs will clear in the front, it will fit. If they don't clear, then you have to put smaller drivers on. If you have to go down to a 7 tooth, make sure you get extroverts.
With a smaller driver there is less contact at all times with the track requiring you to run your track tight. Extroverts let you run it less tight and the track won't slip on the drivers. I think this is what he's getting at.I'm looking at doing the same thing to a Powder Special. I think that I have to change drivers so why would I put on extroverts? what's the advantage?
thanks
