anybody have any tricks for removing the primary clutch from a mm700? Thanks Scott
Note: this_feature_currently_may_not_be_available_in_some_browsers
put a dab of antiseize on the tip, and it creates kind of a hydraulic pressure if you can get it in there without takign too much off the top...that helps more than you would think...thanks guys, i have the corect puller I will try adding some grease and maybe give it a hit with the impact. Scott
