155 sks cracked rail, weldable? Aftermarket options?
M
moex
64
12
8
Right hand rail is cracked behind the shaft of the front arms. The bottom of the rail seems ok but the top triangle part is cracked. Is this type of aluminum?weldable?? I see ice age as an aftermarket option. Any others? New black rail from Polaris is 640$ a little pricey. Not sure I can load a pic. TIA
Mo.
MKULTRA
493
349
quebec, canada
yes you can weld it but don't expect it to last long. I would add a stiffener if i were to weld it.
one more option for you, get a used rail. New stock rails are the price of ice age, no point in buying new stock ones
Wheel House Motorsports
29,933
5,968
SW MT
Welding heat treated alum doesnt work. It breaks right around the weld.
Really no reason to not go iceage as mentioned, cheaper for a kit then single beams from the factory, stronger, and a warranty.
mountainhorse
18,606
11,814
West Coast
www.laketahoeconcours.com
7129T-5 Aluminum does not weld very well... sure, you can melt it together...but it won't hold up.
You could make a pattern, cut it out in some 3/16' 6061 T-6 ... one for each side and bond it with the Lord Adhesive.
Or just buy a new pair of Ice Age rails.... get a pair of Arctic cat 8" wheels and you will have a stronger set of rails... and be into them for less than one rail from the factory.
LoudHandle
3,900
2,775
Valdez, AK
Its an ally issue not a heat treat issue, FWIW
You are misinformed. The difference here is the alloy (7000 series non weldable). Weldability has nothing to do with heat treated or non heat treated, it is an alloy issue. FWIW
