Upgrade to Premium
Ski-Doo: REV Gen 4 For the 2017 and newer REV Gen 4 Sleds
Reply
  #1
Old 01-14-2018, 10:33 AM
walker walker is online now
Currently: Not set.
walker has a reputation beyond reputewalker has a reputation beyond reputewalker has a reputation beyond reputewalker has a reputation beyond reputewalker has a reputation beyond reputewalker has a reputation beyond reputewalker has a reputation beyond reputewalker has a reputation beyond reputewalker has a reputation beyond reputewalker has a reputation beyond reputewalker has a reputation beyond repute
Default Any one having any problem with exhaust valves
Last couple times out sled felt like it was loading up on bottom end. Once it hit 6000 it ran fine. Pulled rpm and hills fine. Then couple hours into ride yesterday rpm started falling off. Then roped out at 7000. Pretty sure exhaust valves where not opening. I have a can on it. Not exhaust note change at 6000. Pulled off servo checked cable operation. Seems to open and close. I have to push last 1/4 inch of valve return to achieve fully closed exhaust valve. Do not know of this is normal. Put sled back together. Seems to run 90% better. Just not quiet right. Sled has 1000 miles on it. No check engine light. Anyone have any idea. What maybe going on. Or how to adjust valves.
Rate this post: Yes | No
  #2
Old 01-15-2018, 02:12 PM
Thistledoo's Avatar
Thistledoo Thistledoo is offline
Currently: Bring on the POW!! and dont be shy!!!
Thistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond repute
Default
probably rave valve motor or secondary inj wiring issue...both common!
__________________
MCX BOV springs to make the BOV actually work proper...pm me for details
Copper exhaust doughnuts for rear mount yamahas...pm me for details
The Following User Says Thank You to Thistledoo For This Useful Post:
walker (01-15-2018)
  #3
Old 01-17-2018, 05:47 PM
FEZ FEZ is offline
Currently: Mechanic for and Advisor to SHR
Basic Member
FEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond repute
Default
need to have dealer adjust valves.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #4
Old 01-18-2018, 04:44 PM
Currently: Not set.
Default In the shop now.
Hopefully they find something wrong.
  #5
Old 02-05-2018, 01:12 AM
Currently: Not set.
Default Fixed problem
Took sled to dealer. 2.5 weeks later they cleaned rave valve and replaced sensor. This is what I was told was the problem. They also replaced servo. Rode yesterday runs great. Just getting back in case anyone has same problem.
The Following User Says Thank You to walker For This Useful Post:
Kingofthehilllpg (02-06-2018)
  #6
Old 02-05-2018, 06:08 AM
stmike stmike is offline
Currently: Not set.
stmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond repute
Default
Are dealers rely that busy ,2.5 weeks ,or are parts that hard to get.
  #7
Old 02-05-2018, 09:30 PM
Currently: Not set.
Default Warranty
It was under warranty. So they had to wait in ski doo to authorize every part they put on.thst is what they told me took so long. Then the parts where 5 days out.
  #8
Old 02-11-2018, 11:12 PM
Tom 42 Tom 42 is offline
Currently: Grip it and rip it!!!
Basic Member
Tom 42 has a reputation beyond reputeTom 42 has a reputation beyond reputeTom 42 has a reputation beyond reputeTom 42 has a reputation beyond reputeTom 42 has a reputation beyond reputeTom 42 has a reputation beyond reputeTom 42 has a reputation beyond reputeTom 42 has a reputation beyond reputeTom 42 has a reputation beyond reputeTom 42 has a reputation beyond reputeTom 42 has a reputation beyond repute
Default
Quote:
I had a power valve problem out of the box. I was having some clutch work done and the shop said that the dealer set it up wrong. It was getting stuck. I’m glad I took the sled to a small shop that runs on reputation alone. I didn’t even ask them to look into it.
  #9
Old 02-12-2018, 04:00 AM
fredw fredw is offline
Currently: 850 blown up before Breakin over
Basic Member
fredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond repute
Default
2.5 weeks is BS, we the owner should not be accepting that!!
No other industry has such bad service like we get!! Call brp and bitch!!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Etec power valves problem Thread Starter — Destroyer Forum — Ski-Doo: XM Sleds Replies — 5 Last Post — 01-20-2014 08:23 PM
Thread — cleaning exhaust valves,Do I have a problem Thread Starter — ENDO1 Forum — Polaris: Pro-Ride Replies — 12 Last Post — 03-17-2013 10:00 PM
Thread — 08 D8 exhaust valves Thread Starter — Sativa Forum — Polaris: IQR Replies — 1 Last Post — 02-06-2012 08:20 AM
Thread — ? On Exhaust Valves Thread Starter — Pro-8250 Forum — Polaris: Pro-Ride Replies — 2 Last Post — 01-31-2012 07:30 PM
Thread — Need M7 exhaust valves Thread Starter — Ski-Laxn Forum — Engine/Engine Parts (Swapmeet) Replies — 1 Last Post — 10-03-2010 08:48 PM
