Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 10-12-2017, 11:03 PM
M8ltd16 M8ltd16 is offline
Currently: Not set.
Basic Member
M8ltd16 is an unknown quantity at this point
Default Team clutch kit
Looking for recommendations on a clutch kit for a 2016 m8000 ltd.
in Ontario so sea level and not always easy to get parts from the states.
Pretty sure my dealer deals with speedwerx so theres that.
Fairly new with real sleds but know enough to realize the clutching isn't so great.
Rate this post: Yes | No
  #2
Old 10-13-2017, 06:54 AM
Old & slow Old & slow is offline
Currently: Not set.
Old & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond repute
Default
You may also want to consider that the 3 inch tracks are not great on trails and aren't build for speed. Not sure of your intended use but a 2.6 is better but still not real trail friendly. That being said the 2016 ltd is geared at 19/50 with 7 tooth drivers. That was to slow for deep snow at elevation riding, I geared mine to 21/49. The clutch kit will need to fit your usage, so a little more info on what the machine will be doing would help. If i was building a M 8000 ltd for low elevation I would be using a smaller lug track, 8 tooth drivers, re gearing and then clutch it accordingly. I hope this helps.
The Following User Says Thank You to Old & slow For This Useful Post:
Bills R.E. Repair (10-13-2017)
  #3
Old 10-13-2017, 02:31 PM
Currently: Not set.
Basic Member
Default
Alright thanks for the input. I gusse i should have mentioned theres no trails for this guy. I may be in the "flat lands" but i make the best of it. Technical tree riding is what i do. Im not the type to go straight up the hills we do have.
That being sayd im not looking to spend a ton of money. Just feel like there's a alot to be gained. I really figured gearing would help. I replaced the aluminium sprocket with a steel one (just for piece of mind) and was going to gear it up a bit but dealler suggested otherwise. I think he thought i just wanted to go "faster".
So maybe im just better off gearing it up and see how that works. Is a different length chain needed to do that?
  #4
Old 10-13-2017, 06:11 PM
knifedge's Avatar
knifedge knifedge is online now
Currently: Not set.
knifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond repute
Default
MDS probably work pretty well down there..
Not sure seconndary setup though....XF helix and spring most likely
Yeah, research the XF setups then go from there..
  #5
Old 10-14-2017, 07:39 AM
Currently: Not set.
Default
The chain will fit on a 21/49 set of gears, AC re-geared in 2017 to 21/49 on all the M sleds with 7 tooth drivers. The helix in your sled should be a 48 and that is made for elevation, there is big gains to be had. A softer secondary spring and more primary weight is also needed.
  #6
Old 10-15-2017, 05:09 AM
JammerMan JammerMan is online now
Currently: Not set.
Basic Member
JammerMan has a reputation beyond reputeJammerMan has a reputation beyond reputeJammerMan has a reputation beyond reputeJammerMan has a reputation beyond reputeJammerMan has a reputation beyond reputeJammerMan has a reputation beyond reputeJammerMan has a reputation beyond reputeJammerMan has a reputation beyond reputeJammerMan has a reputation beyond reputeJammerMan has a reputation beyond reputeJammerMan has a reputation beyond repute
Default
I run mds weights with a Polaris black primary spring cat sea level secondary spring with cat sea level multi angle helix . Also re geared to 21/49 here at sea level it pulls hard
  #7
Old 10-15-2017, 01:09 PM
sno*jet sno*jet is offline
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
id start with factory stuff, make sure dealer did low elevation calibration (on a 17 it was different drive spring and weights)
then do the gearing as suggested.
then ride it a lot in your honey holes and see if its not just perfect. jmo.
  #8
Old 10-25-2017, 07:30 PM
Currently: Not set.
Basic Member
Default
Thanks for the help guys. My dealler says its the low elevation clutching in there. Ill do the gearing and take it from there
The Following User Says Thank You to M8ltd16 For This Useful Post:
Bwhite (10-27-2017)
  #9
Old 10-26-2017, 01:31 PM
DalensM8 DalensM8 is offline
Currently: Not set.
Basic Member
DalensM8 has a reputation beyond reputeDalensM8 has a reputation beyond reputeDalensM8 has a reputation beyond reputeDalensM8 has a reputation beyond reputeDalensM8 has a reputation beyond reputeDalensM8 has a reputation beyond reputeDalensM8 has a reputation beyond reputeDalensM8 has a reputation beyond reputeDalensM8 has a reputation beyond reputeDalensM8 has a reputation beyond reputeDalensM8 has a reputation beyond repute
Default
Contact Kevin Hubbard at Hubs Performance.com, he has developed a clutch kit for the 2016 limited. He also recommends gearing up.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Team Tied Clutch Kit #520900 Thread Starter — SSE Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 0 Last Post — 01-22-2015 10:05 AM
Thread — Clutch kit or Team Tied Conversion? Thread Starter — Torgenrud Forum — Ski-Doo: XM Sleds Replies — 5 Last Post — 12-03-2014 06:39 PM
Thread — Team Secondary or RK Tech clutch kit?? Thread Starter — geisp Forum — Arctic Cat: M Series Replies — 2 Last Post — 12-04-2010 08:00 PM
Thread — Team Clutch Kit Thread Starter — Skadi Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 8 Last Post — 09-29-2010 10:25 PM
Thread — Team Clutch or DJ Clutch Kit Thread Starter — Redsledhead Forum — Clutching Replies — 9 Last Post — 10-31-2009 05:30 PM
