Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 10-09-2017, 12:32 PM
boondocker97 boondocker97 is online now
Currently: paying bills
boondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond repute
Default Secondary Maintenance Fix
I just wanted to let people know some things I found related to my jackshaft/secondary when I rebuilt my sled last spring that might be helpful. I have a 2014 model chassis and I swapped out the tunnel/bulkhead for a 2017 MC (long story, plan to do a full write-up later). When I changed out the jackshaft for the 2015 unit, I noticed my clutch side bearing was going out with 1600 miles on it. Then when I was re-aligning my clutches I noticed that one of the washers that goes between the secondary and the jackshaft bearing was worn. A lot. It was a 0.030" shim washer and the clutch had worn into it by about 1/2 it's thickness. I was noticing some inconsistency with back shifting before this re-build. I'm guessing the combination of the worn bearing and the 0.015" wrong offset were causing the issues.
Just something simple to check for you guys with "old" sleds like me.
__________________
Current Sleds:
2014-2017ish BDX Pro-Lite 900, 2005 M7 with upgrades - Ol' Reliable, 1974 Cheetah
Still in the Family:
2009 M1300, 2001 Mountain Cat 800 LE, 1972 Kitty Cat
Gone but not Forgotten:
1999 Powder Special 600 LE, 1998 Powder Special 600, 1993 EXT 550, 1980 JAG 340
Rate this post: Yes | No
The Following 5 Users Say Thank You to boondocker97 For This Useful Post:
Bills R.E. Repair (10-13-2017), Frostbite (10-09-2017), knifedge (10-11-2017), line8 (10-09-2017), snowcannon (10-09-2017)
  #2
Old 10-11-2017, 01:14 AM
WyoBoy1000's Avatar
WyoBoy1000 WyoBoy1000 is offline
Currently: Working,
WyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond repute
Default
Send to Mountain Valley in CODY, WY
Get it machined, balanced and rebuilt. It will blow your mind how much better it works and will pull way harder. Better than the 16+
__________________
18 mc (ufo) mods
16 limited, raised axys boards, xm-adjustable riser, mountain for hood, 8t drivers, ds can, slp exhaust. (Coming tki drop belt Drive) then clutch until happy.
Assume = when you as$,u,me you make an as$ out of u and me. Think, ask, get the facts and then go forward.
  #3
Old 10-11-2017, 09:34 AM
IgnantJr IgnantJr is offline
Currently: Not set.
Basic Member
IgnantJr has a reputation beyond reputeIgnantJr has a reputation beyond reputeIgnantJr has a reputation beyond reputeIgnantJr has a reputation beyond reputeIgnantJr has a reputation beyond reputeIgnantJr has a reputation beyond reputeIgnantJr has a reputation beyond reputeIgnantJr has a reputation beyond reputeIgnantJr has a reputation beyond reputeIgnantJr has a reputation beyond reputeIgnantJr has a reputation beyond repute
Default
Is that just for secondary or do you send em your primary with it?
  #4
Old 10-11-2017, 09:53 AM
Cat00's Avatar
Cat00 Cat00 is offline
Currently: Not set.
Cat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond repute
Default
Just the secondary I just got mine back from them last week
  #5
Old 10-12-2017, 10:45 AM
skibumsd skibumsd is offline
Currently: Not set.
skibumsd has a reputation beyond reputeskibumsd has a reputation beyond reputeskibumsd has a reputation beyond reputeskibumsd has a reputation beyond reputeskibumsd has a reputation beyond reputeskibumsd has a reputation beyond reputeskibumsd has a reputation beyond reputeskibumsd has a reputation beyond reputeskibumsd has a reputation beyond reputeskibumsd has a reputation beyond reputeskibumsd has a reputation beyond repute
Default
I have a silber turbo on my 14 m8000. Is the machining process the same, or do they do a different setup since its turbo?
  #6
Old 10-12-2017, 11:36 AM
Cat00's Avatar
Currently: Not set.
Default
They machine the sheeves to match the angle of the belt and put a lighter spring in. Tell tom your running a turbo he'll get you set up
  #7
Old 10-12-2017, 05:46 PM
Default
If my clutch isn't shifting like I think it should after this then I might consider the machining. If it seems fine then it'll stay the way it is. Was working pretty good up to this point and I don't want to fix what isn't broke.
I also got to thinking that maybe that washer wearing out is related to the mysterious occasional loose secondary bolt. Either the washer wore and created slack for the bolt to loosen, or the bolt loosened up and wore the washer. Just something else to think about.
__________________
Current Sleds:
  #8
Old 10-12-2017, 07:47 PM
Wheeeezy9 Wheeeezy9 is online now
Currently: Not set.
Basic Member
Wheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond repute
Default
what is the cost for having the sheaves machined or what is the website to look at to get that info?
  #9
Old 10-12-2017, 08:50 PM
Cat00's Avatar
Currently: Not set.
Default
I'd have to double check but the machining a new spring and shipping I want to say was 350ish. Also the clutch I sent in was brand new so nothing needed rebuilt
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — noisy secondary fix Thread Starter — Insaneboltrounder/sjohns Forum — Arctic Cat: Proclimb M Replies — 6 Last Post — 11-15-2016 09:35 AM
Thread — Team secondary helps but not fix Thread Starter — Cold_puss Forum — Arctic Cat: 1100 ProClimb Replies — 19 Last Post — 02-14-2013 08:37 AM
Thread — Rkt Secondary Fix?? Thread Starter — M7ALLTHEWAY Forum — Arctic Cat: M Series Replies — 41 Last Post — 11-25-2010 05:38 PM
Thread — RK Tek Diamond Drive Secondary Fix Thread Starter — CatmanTimmay Forum — Mountain/Deep Powder Replies — 13 Last Post — 02-14-2009 02:50 PM
Thread — RK Tek Secondary Fix on M7? Thread Starter — biggie72 Forum — Arctic Cat Replies — 8 Last Post — 06-06-2008 07:29 PM
