J
I know its been discussed in previous threads but I'd like to have one place where we can post our suspension setups.
Include track lug/length, suspension type and if you've done any custom work...
For me...
163" 2.6" Stocker
IFS: 36" Z-Broz setup set in "wide" position. 1/2" shorter front shocks. Revalved for stiffer compression tune. 2 turns of preload. Spindle slight positive camber. (less than 1/2 degree)
FTS: Factory Spec
RTS: Factory Spec
Sway bar attached.
Sled is pretty good in untracked soft snow but a bit of a handful in tracked out/off camber harder snow (as expected). Considering dual rate front springs. I often find myself "over riding" the sled.
Also due to ski lift, considering a firmer compression tune and additional preload on the rear track shock and removing preload from the FTS.
For me...
163" 2.6" Stocker
FTS: Factory Spec
RTS: Factory Spec
Sway bar attached.
