J
Hi,
Just need to know the correct way to disconnect the two choke cables from the carbs.
James
James
Note: this_feature_currently_may_not_be_available_in_some_browsers
Unscrew the brass fitting that is on the carb where the choke cable goes in. If the cables won't let the fitting rotate then it is corroded and you will have to soak it with some kind of rust dissolver. When you get the fitting out you can compress the small spring and slip the ball end of the cable out of the choke plunger.
