2007 apex wont start
Dec 31, 2008
3
Ok hoping this is in the right spot and not in the classifieds lol
My problem took the sled out yesterday short little ride just got back in my yard and it quit Called the dealer we check for error codes NONE so he said change the plugs I did still wont start turns over just fine charged battery just in case still wont start. So now I am looking for fuses and fuel pump relay this is a new sled for me and never worked on Yamaha before so I don't know where anything is located....The manual is no help at all. ANYBODY please if you have pictures that would be GREAT
C
canuck5
60
13
8
Sylvan Lake AB
So it cranks and your have spark.......the obvious question is do you have fuel pressure or is your fuel pump primeing when you turn the key on?
E
Extreme-One
105
Meridian, ID
There are fuses above the chain case under a black molded cover and a few more behind the oil tank just in side the frame by the battery. If your sled is stock your fuel pump is in the fuel tank, pull the seat and check that you have power. You might have lost the fuel pump.
