Y
Just put a new top end, SLP pipe and can on my 07 RMK 600, and now it doesn't run quite right, haven't had too much snow to test it, but it does the following:
If I run it at right about 4000 RPM, say turning around in the yard, it will bog and backfire, seems to clean up if I flip the choke on
This one is less important as I haven't fully tested it:
seems to fall on its face if I punch the throttle from idle. I think I have my air screw at stock, plus a half turn open, Im going to close it 3/4 turns later and see if the bottom cleans up, but what about mid range?
I already have the .9 pilots, 440 mains, and the needle at SLP spec
Just put new clutch stuff in as well SLP spec weights and springs
TPS was checked last year and was set to spec, will re re-checked tonight, one new carb boot, one not leaking, checked by spraying starter fluid on it, will be slated for replacement soon though.
riding at like 800 feet. to 1500
