-Remove your bars from the post
-Remove the heat sheild plate on the triangle shaped frame, and pay attention to the location of your wires. depends how the wiring is in there, you might have to cut some ties and re-fasten them later.
-Remove the bolt that holds your steering arm to the post
-remove the 2 nuts in front of the post at the top off that triangle shaped frame
-remove the bolts on each side of the triangle shaped frame. There's two on each side.
-Then there's a nut that holds your post down to your bulkead. Look in front of your track drivers. You'll need an extension.
Once that is done pull the old post out and put the new one in. When you put it back together make sure your alignment is good. Just adjust it with your steering arm.
It's not a tough job.
