I found that orange spring to be just to much. I know every sled, conditions and rider preference will be a bit different, and there is more than one way to get results. I had 75-77g weights on my ET900 and a 162 track,and found GREAT backshift with a 36 and a mild spring (160/240 Team). Remember that it's the helix and not the spring that tackles most of the backshift force. Too much spring just keeps the helix from being about to do it's job IMHO.
Also, a 44/40 is too steep for a 162 in the hills. Fine for shorter tracks, but a 36 is pretty much mandatory with a 162 if it's used in the steep/deep.
With a shallower helix there is no need for huge spring pressure in the secondary.
I think the problem stated by the originator of this thread is a combination of the 44/40 and the XS belt holding down RPM. Put in a 36, a softer secondary spring, and a stock belt and you will see 90.
Also make sure the rollers are in good shape, any sign of flat spots and they cause problems.
