Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 12-31-2015, 01:32 PM
Jonathanpitzl's Avatar
Jonathanpitzl Jonathanpitzl is offline
Currently: Not set.
Jonathanpitzl has a reputation beyond reputeJonathanpitzl has a reputation beyond reputeJonathanpitzl has a reputation beyond reputeJonathanpitzl has a reputation beyond reputeJonathanpitzl has a reputation beyond reputeJonathanpitzl has a reputation beyond reputeJonathanpitzl has a reputation beyond reputeJonathanpitzl has a reputation beyond reputeJonathanpitzl has a reputation beyond reputeJonathanpitzl has a reputation beyond reputeJonathanpitzl has a reputation beyond repute
Garage
Default Help!!! Lights and gauge sometimes not working
My 05 m7 is having a gauge and headlight problem that has happened 4 times now
While going down the trail it would suddenly cut out and not run right. When that happens the gauge and headlights stop working.
I wiggled the harness a bit and nothing would happen so I went down the ditch a little more slowly and it came out of it.
Buddle of mine said it's probably the voltage regulator, is there a test for that?
Any help would be much apreciated since I'm leaving on Monday for cooke city.
Rate this post: Yes | No
  #2
Old 12-31-2015, 05:26 PM
Vern Vern is offline
Currently: '14 m8 SP 153-hyvos, dmnd-s, anti-stb,
Vern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond repute
Garage
Default
Check for electrical shorts, these sleds are notorious for little shorts causing all kinds of wierd stuff. I had the same thing you describe happen on my m7 and it was the harness going to the bars got pinched in the steering stop on the post. Fixed that and was good again. Other common areas for shorts on the m7 are at the rear tail light and I believe where the tail light wires exit the tunnel above the brakes
  #3
Old 01-01-2016, 07:06 PM
kidwoo's Avatar
kidwoo kidwoo is offline
Currently: schmurrently
kidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond repute
Default
^Yup.
A buddy's 08 had the same issue. His was the tail light wire.
__________________
www.sierrasnowmobilefoundation.com
Your loud can sounds stupid
  #4
Old 01-02-2016, 09:00 AM
sledtahoe sledtahoe is offline
Currently: waiting for the big dump!
Basic Member
sledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond repute
Default yes
same thing happened when the hand warmer was shorting on bars for me
The Following User Says Thank You to sledtahoe For This Useful Post:
Jonathanpitzl (01-03-2016)
  #5
Old 01-02-2016, 09:36 AM
Sledbrain2 Sledbrain2 is offline
Currently: Not set.
Basic Member
Sledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond repute
Default
hope its just a wire, I have an 06 m7, at 1500 miles the stator quit working, stock exhaust and venting, I have since opened up the exhaust side with vents. If you cannot find a bad wire I would get a stator to bring with you, its not too bad of a job to fix as long as you do not have to do it on a trailer.
  #6
Old 01-02-2016, 11:58 AM
Currently: Not set.
Garage
Default
I looked for signs of shorting but couldn't find anything, and did a bunch of harness wiggling and couldn't make it happen
  #7
Old 01-03-2016, 11:14 AM
Currently: Not set.
Garage
Default
Quote:
You were right, I wiggle that wire around and that was the problem, unplugged the hand warmers and it was good as new! Thanks for the help!!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Gauge and tail lights not working! Thread Starter — eminemin Forum — Polaris: Pro-Ride Replies — 20 Last Post — 12-26-2014 07:51 PM
Thread — Gauge and Tail/Brake Lights quit working Thread Starter — leeindubois Forum — Arctic Cat: Proclimb M Replies — 4 Last Post — 12-26-2013 06:49 AM
Thread — All Lights working except headlight... help!!! Thread Starter — Skibum173 Forum — Ski-Doo: ZX Sleds Replies — 0 Last Post — 12-07-2013 12:47 PM
Thread — Lights and RPM gauge quit working Thread Starter — czach Forum — Ski-Doo: ZX Sleds Replies — 6 Last Post — 03-12-2010 12:47 AM
no new posts
