Upgrade to Premium
Arctic Cat: Powder Special and older 2000 and older, all models in the Powder Special chassis and older chassis models
Reply
  #1
Old 11-13-2013, 09:30 PM
KKRRSS KKRRSS is offline
Currently: Free sleds now running
Basic Member
KKRRSS has a reputation beyond reputeKKRRSS has a reputation beyond reputeKKRRSS has a reputation beyond reputeKKRRSS has a reputation beyond reputeKKRRSS has a reputation beyond reputeKKRRSS has a reputation beyond reputeKKRRSS has a reputation beyond reputeKKRRSS has a reputation beyond reputeKKRRSS has a reputation beyond reputeKKRRSS has a reputation beyond reputeKKRRSS has a reputation beyond repute
Default Broke something on carb
96 powder extreme.
all three carbs have a little black rectangle plastic thing screwed to the side (what is that?)
Only one carb has a larger aluminum block with a tube on it that goes into a plastic fitting in the carb. There are two wires, one broke off (looks like it was soldered). What is this and can it be repaired?
Thank you.
Krs
Rate this post: Yes | No
  #2
Old 11-13-2013, 09:53 PM
Idcatman1's Avatar
Idcatman1 Idcatman1 is offline
Currently: Not set.
Idcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond repute
Default
If the little black plastic rectangle thing has two wires on it, it is part of the throttle safety switch that kills the engine if the throttle sticks. I have had a boat load of troubles with them on many Cats over the years. I usually take them off and jumper the wires on the chassis wiring harness that they plug into. The other block with the two wires is part of the altitude compensator and the wires go to a heater so it doesn't ice up and quit working in deep powder. Hope this helps.
  #3
Old 11-14-2013, 07:15 AM
Basic Member
Default
That does help. I will try and resolder the wire to the altitude thing.
I had better research the little black thing, so i can bypass it on the trail if needed.
Thank you for your help.
  #4
Old 11-14-2013, 05:57 PM
Idcatman1's Avatar
Currently: Not set.
Default
Those sleds came with a little wire loop two prong plug that was used to bypass the throttle safety switch if it went on the fritz. If you are lucky it is still in the sled somewhere. There was also a small canvas pouch with a few tools that might have been with it, the plug should be in there if you got the tool bag. Good luck.
  #5
Old 11-28-2013, 05:00 AM
RCR3 RCR3 is offline
Currently: I AM RASMUSSEN STYLE
RCR3 has a reputation beyond reputeRCR3 has a reputation beyond reputeRCR3 has a reputation beyond reputeRCR3 has a reputation beyond reputeRCR3 has a reputation beyond reputeRCR3 has a reputation beyond reputeRCR3 has a reputation beyond reputeRCR3 has a reputation beyond reputeRCR3 has a reputation beyond reputeRCR3 has a reputation beyond reputeRCR3 has a reputation beyond repute
Default
(HAC) HIGH ALTITUDE COMPENSATION System it was a joke on a lot of PUTTER EXTREMES!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 40mm mikuni rack carb, 1 carb only! Thread Starter — flying pig Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 02-05-2012 09:26 AM
Thread — 02 carb vs 03+ carb and jetting differences Thread Starter — ullose272 Forum — Polaris: EDGE Replies — 38 Last Post — 02-08-2010 09:25 PM
Thread — 02 polaris carb slide broke off Thread Starter — spr Forum — Polaris: EDGE Replies — 5 Last Post — 10-30-2009 10:15 PM
Thread — 1m? 02-03 800 carb or 900 carb electric start Thread Starter — DCAMPBELL Forum — Arctic Cat (Swapmeet) Replies — 2 Last Post — 09-28-2009 08:13 PM
Thread — 98 mxz 670 carb question? plug in mouth of carb hole?? Thread Starter — BOOMINBLUEFORD Forum — Performance/Modified Replies — 4 Last Post — 02-19-2008 01:19 AM
no new posts
