2013 belt
P
paulharris
1,348
549
Colorado
are the dimensions of the 2013 summit XM belt the same as the summit XP? Not concerned about compound, just dimensions.
J
Feb 15, 2003
483
31
Greenfield, MN(55357)
Yes....different compound but the clutches and center to center are all the same.
Hey winter brew,
So do you think the 377 belt would work fine as a backup/spare belt or should I spring for the belt listed for this specific sled application? If it would only be good to get me out of the back country only to have to search for the belt that comes on the sled then I would be better off just selling the 2 brand new 377's I have and buying the exact replacement belt... Your thoughts?
Thanks again,
-John
Matte Murder
3,579
2,259
Are the 12 belts the exact same belts as the 13XM?
-lenny-
385
162
Whitecourt, Alberta
In the accessory catalogue, part 417300391 is listed as the belt for the 800 Etec for the Rev XP, Rev XR, Rev XU, Rev, Rev XM, and Rev XS.
winter brew
4,332
LakeTapps, Wa.
isn't the 391 an upgrade to the 377? different compound.
I never had isues with either belt. IMO the -391 will put down the power a little better as it seems to be a softer compound (stickier when hot). Slight clutching tweaks might be necessary when changing compounds.
Both are good belts.
