P 1563 Code
K
48
Cle Elum, Wa
I have a 2014 Summit 800. The check engine light came on when I was riding and the sled lost all power. I could shut it off and start it up and it would idle fine. It would run good for about 150' then lose power again. It's showing P 1563 as the code. Any suggestions for an at home fix?
dps
88
35
18
Leeds ND
P1563 ECM
High Voltage on system voltage circuit
Damaged circuit wires, connector or ECM
Check for inverted wires on magneto connector, loose connection on
connector on capacitor
K
48
Cle Elum, Wa
Thank you!
QUOTE=dps;4114942]P1563 ECM
connector on capacitor[/QUOTE]
