Note: this_feature_currently_may_not_be_available_in_some_browsers
depends on year, chaincase sleds need the case modified for 7t 3.0 pitch drivers(track rubs case) quickdrive sleds its good to go. if you get center drive drivers and track you don't need the anti-stab or trim rails.
I'm running a 2013 Assault which has the chaincase. I was planning to move to a TKI belt Drive system anyway. Do you know how that plays into this puzzle?
I don't think Tom makes a chaincase kit anymore. You buy the stock back plate from a belt drive sled. Install that. Then you do not have clearance issues either.
When I talked to him mid summer he said he still does but you have to call him to get it. No longer on the website.
Just so I'm clear on this. The driveshaft is mounted in the same location on both models (PRO RMK with the factory belt drive and the Chaincase model). however its the back side of the chaincase that is hitting the track that is causing the problems. Do I have that right?
Yes, here is a link that explains the process pretty well. The procedure for the X3 and 280 are the same. http://www.snowest.com/forum/showthread.php?p=3974982#post3974982
Do you have one in hand? Im really impressed, thats 2lb less than I saw advertised.The actual production weight of a 154" track is 40 pounds.
