M
I just recently installed a Race Pak Avenger 2 EGT gauge to my 600 HO mod. I bought the unit used, cleaned it all up put new batteries in etc... My question is at Idle the egts read like 200* apart is that normal or is one of the sensors going bad?
I never swaped the other sensor into the other pipe to do a check that way. The motor starts and idles nice.
Even under wot the one sensor/side reads 200* off. Both are the same distance from the piston.
My thoughts are its a bad sensor... That sensor was all warped from heat before I put it in.
The motor is all fresh, new crank new pistons etc...
Can anyone with experience with EGTs help me out?? What is the typical life of a fast response probe???
Thank you.
Thank you.
