L
Hi all!
I was riding down a road about 2 miles into a slow ride, at about 25 mph. 700 RMK VES, all original and stock.
Machine had warmed up a bunch before being unloaded, and was completely warm. It started and ran perfectly. It has 900 miles since new. A real creampuff. Conservative jetting, and no changes since it was born.
It locks up solid with no warning. No det flash. I can't pull the rope, use the e-start, or move the crank by hand by spinning the primary clutch. After 20 minutes, I can move it. It starts again but locks again after a few seconds. Piston seizure, right?
I tow it out, get it home, and take the head off, expecting to see bad things. The plugs looked chocolately good, no deto marks anywhere. No scored piston or cylinder. It looked perfect. Compression is 120 per side at 6,000 feet. Oil line with VES gold are full, and there is the right amount of oil on the cylinder walls. No old gas, it was flushed right to the carb bowls within the last month, and started and run plenty before today.
Puzzled, I put it back together. It start up perfectly, idles like new for 20 seconds, and stops and locks up again. I take the head off, still looks perfect.
I fully expected some freaky top end problem, but I don't see it. The exhaust valves haven't hit anything, the clutch isn't loose like a crank problem.
What am I missing? I hate to take it apart further. My repair budget is somewhere near zero.
