J
Ok guys maybe you can help me out on this.. Last year I traded a bike for an 03 800 rmk vert edge. When I traded I knew that the Pto side cylinder was bad.. So I tore it down sent the cylinder to have it replated.. The other cylinder looks like it was just done and has a Wiseco piston.. So while I was in there I put a big bearing kit in it bored the cases and put new seals in the bottom end.. I put a wiseco piston in the burnt down side to match the other and new rings in both.. I cleaned the carbs and put it all back together and it ran great.. I heat cycled the motor and ran oil in the gas. I rode it 3 rides last year. So I get it out this year and we head up the trail and half way to the top it loses the pto side cylinder again....... It was jetted the same as last year for the same location and the same temp and it was running great then, I was going to go to the top and check the plugs but I didn't make it that far and the other cylinder when I pulled the plugs it was chocolate brown.. The intake side of the piston is really bad.. The pin bearing also does not look to be in good shape..
Am I missing something here guys??? A friend thinks it is the wiseco pistons... But the other side looks brand new..
Mods
Slp twins
v-force 3 reeds
de comp holes plugged
wiseco pistons
big bearing kit
Any help would be great!!
Mods
Slp twins
v-force 3 reeds
wiseco pistons
big bearing kit
