can't say if this is the fix all for everyone but the reflash is here. see update kit post.
The update kits are out as of today. There are two different kits depending on 07-08 models. Applicable sleds are Crossfire and M 1000cc. ECU will be reflashed at your dealer as well as additonal parts for the stock exhaust and intake system.
Service Bulletin states the kits are to enhance the performance in deep snow and side hilling of the sleds in STOCK configuration.
Parts were available at A-Cat when I checked today.
07 Models 0637-316
08 Models 0637-317
Thanks,
Steve W.
Been answering calls today on the service bulletin release 2/12/09 by Arctic Cat. This service bulletin (actually 2 bulletins...one for 2007 .... one for 2008) is a high altitude update that will include the exhaust deflector, rubber boot etc to update it like the 2009 model. The ECU reflash is BASED on the 2009 ECU. It is different for both models due to ECU differences, Exhaust differences, as well as the AC/DC difference....but should have the same driveability as the 2009.
I will post info on the reflash as will be testing this weekend. PM me if you have questions. Call your local dealer to schedule this update and give them some time to get the parts in as well as realize that the parts will most likely be on backorder after this week due to demand.
The bog comes in at about 4000 RPM + or - 200 rpm. If I hold the throttle in a position that allows the sled to slow down and stop, the engine will flat out die. Every time. (I've only tried this when the engine was warm) Others with the bog should try this test and report back if their bogger does the same please.
WELL its about timw we talked about this new flash update. Mine is also very fat it almost falls on its face from 6200 to 6800 rpm,s. Spitts out black smoke runs good to 6200 rpm and at wot this is epa aproved???????? who paid off who? Mine also used to get 8 to 9 mpg. Just did the math and its now at 6 but i did not buy this thing for fuel milege Oh it is a 08 M1K SP. Just do not under stand why its so rich. The higher i go the worse it is i sure hope AC can help with this.....................
Did you have a bog that caused the engine to die? Did yours bog and die when you were off the throttle? Mine does, so I dont think thats clutching related. I have the other problems everyone else complains about too, which I agree, could verly likely be related to clutching.
If I make a long pull in deep powder and stop and let it idle, then sometimes it does want to die... If I play with the throttle it will come out of it 50% of the time, and want to die the other 50.
Have never had it bog if I keep riding though, only if I stop.
I should get to try out the reflash this weekend and I will report back.
i have an 09 with speedwerx y-pipe and custom pipes can....i used a speedwerx big air intake and drilled holes in the front of the airbox only, covered them with frogskinz......put an egt on it, and also a bd box for fuel adjustment......clutched it to suit me.......worked out the fuel bog by removing small amount of fuel in the 5000 to 6500 rpm range and added fuel in the 7200 to 7500 rpm range....clutched to run in the 72-7400 range.....no bog, runs hard, pulls very hard......other 1000s with full exhaust systems, ported etc. still can't run with mine on the hill or a drag race.....xps? not a contest, dragons? is to laugh.....piped xps, not close....dragons on nos? not a chance.....i use a 46 belt and get between 6-700 miles before i change it because it has narrowed down enough that the clutching is starting to let it rev too much on a hard pull....these are just the things i have done to make my 1000 what i want it to be...now i just ride.
