1
Bought an 08 nytro with a 162" 2.5 and a fast m10 with cr rails. The sled seems to have alot of ski pressure, limiter strap all the way out, I actually took it off to see if theres more front shock travel and theres not so that is as long as the limiter can be. There is very little pressure on the front of the skid and a lot in the back. I plan to drop either the rear mount further up in the tunnel or drop the front down. either way about a two inch move seems to take care of the ski pressure. So when I removed the rear arm bolts the rear arm sprung up, you need to compress it to mount it back in the tunnel where it was located, Is this proper? Looking if any one knows the distance each bolt should be apart from front arm to rear arm?
