L
Im wondering how long in hours/km the break in is on the new patriot 850?
Note: this_feature_currently_may_not_be_available_in_some_browsers
The success rate on this new engine is more like 98
That idea has been cruising the forums and dealerships for years....I have no idea where it came from. I set it for the fuel I'm using from day 1Exactly where does it state in the manual to run in eth mode during break-in?
Source?
What was posted by ChrisWelters is the correct break in procedure. Once you get past the initial 2 hour mark (time only counts for RPM over 5500), this machine REALLY wakes up. Then, if you run non-ethanol fuel, change the setting to “non-ethanol” and that even wakes it up more. This sled absolutely RIPS!!
Is there a way to tell if you are done with break in hours?
full break in is 10 hrs above 5,000 RPM. Not just 10 hrs of running
10 hours above 5500 RPM is the magic number
I just found out today that I have 3 hours of break in left. Snowmobile has 300 miles and 24.6 hours.
Sent from my SM-G965U using Tapatalk
That is correct. They have to do a little math from what I understand.Did you get this info from your dealer ? They plug it in and they can tell?
This is from the shop manual.
