P
how to use the rbi properly not understanding maps and what map is it running now
Note: this_feature_currently_may_not_be_available_in_some_browsers
Do yourself a favour and get rid of it now before it wrecks your season. They are a pain in the butt.
it can only run a good as the rb3 will let it even with the right people doing the tuning, but it certainly wont be as good as it can be or should be. I have a rb3 it works great as a doorstop.
Yes I did try one with powderlites Nytro map and I got sick of it so I took it off before it wrecked my season. I was wondering why all the guys with Powderlites turbo kits had such low mileage, but now I know.Neil do you run a RB3?
How did it wreck your season?
I will email you the manual Passed you.
Questions about EFI we can help out and do our best to make your ride run it's best.
That is exactly the point Dave. How could it work? But then what? People just want to ride, not reach out to someone hundreds of miles away everytime their sled won't run. Even if you built a reasonable base map, it would have to be changed every time someone changed things like cam timing, compression, turbo size, porting, etc. The sleds will even run different day to day based on air pressure and may require more or less fuel...then what? Rapid Bike is simply not user friendly.Neil How could a map for rear mount work on a different setup and turbo system?
Come on I never setup a map for you or that turbo system.
No one ask us for help if there was a problem?
I have been testing a new fuel system on my Nytro and have 6 solid days on it. It took me 5 minutes to dial it in. I have no burbles, hesitations, stumbles, etc. I am getting the best fuel economy and best throttle response of all the Nytro's in our group and I am guaranteed never to be short of fuel. I can adjust exactly when boost fuel is added and how much fuel in less than 30 seconds. It is so simple that it almost sounds to good to be true. We are going to test it on a MCX 1200 Doo with some motor work and I know it will work unreal. This is what people want.
So NM I think you should quit beatin around the bush and tell us what you have. It's the 2nd of June and if its tested enough and good enough for everyone to use, lets hear it now. Some of us may want to make some decisions before the next riding season.I have been testing a new fuel system on my Nytro and have 6 solid days on it. It took me 5 minutes to dial it in. I have no burbles, hesitations, stumbles, etc. I am getting the best fuel economy and best throttle response of all the Nytro's in our group and I am guaranteed never to be short of fuel. I can adjust exactly when boost fuel is added and how much fuel in less than 30 seconds. It is so simple that it almost sounds to good to be true. We are going to test it on a MCX 1200 Doo with some motor work and I know it will work unreal. This is what people want.
Haha. Thanks Shane, but I only buy the parts and make them work on a sled. This is as close as you can get to what MCxpress uses for a fuel system as you can get, but it is fully adjustable with the simple turn of a dial.its nms own system
hey my garage door wont stay open, how much for the doorstop?
As far as I am concerned every Alpine, Powderlites Apex and Nytro kits, and early Impulse kits need this system. The sled simply runs off of the stock fuel settings and injectors until it needs more fuel under boost and then starts to add the fuel. It is the easiest and most logical fuel system for any turbo sled. The best part by far is anybody can tune it in "ON THE HILL" within a few minutes.:face-icon-small-sho:face-icon-small-hap
