New Product - Now in Stock Scratchers
GoBigParts
4,078
917
Michigan
www.gobigparts.com
Ice Storm Ski Mounted Scratchers: I will include the standard hardware in case someone wants to mount them to the plastic on the ski.
These are now in stock along with the Ice Storm Rail mounted scratchers, duraflex and more.
Go Big Parts and Accessories, LLC :: Snowmobile Products :: Slide Savers and Ice Scratchers
Improvements to Ice Storm rails scratchers.
New bending proceess improves spring durability
316 Stainless steel reversible ski
stainless steel cotter pin to hold ski to spring.
Scott
Scott Stiegler
69,618
11,737
W Mont
I have those on my rails. They are awesome.
I think the ski scratchers would be REALLY nice too. Especially on those frozen spring mornings before the sun softens everything up.
gmustangt
1,443
495
83
Are the ski mount scratchers the same length as the rail mounted?
likkerpig
1,298
271
83
Interested.... I'd like to see them in the up position. Also wondering how much extra crap will get flung up at the rider. I get a fair amount of chunks with the factory polaris scratchers.
AndrettiDog
6,329
2,478
Colorado
Have them on my Ice Age Rails on my '13 Pro. Work great. I haven't been able to bend them up.
wjl
2,359
780
Eden, UTAH
OP has link to pictures up.
Look like a good product.
Sage Crusher
3,268
1,196
Rock Springs,Wyoming
SLP had these back in 1994 for their skis-
worked well for the polaris sleds when the cooling was down the running boards-
worked very well to assist in marginal snow- but don't know the concept here where rail scratchers alone seem to keep the spray in the rails and in the tunnel area.
S/C
GoBigParts
4,078
917
Michigan
www.gobigparts.com
Update: The manufacture made a last minute change and the ski mounted bolt does not come with these scratchers due to a few reasons. One being liability.
The scratchers however do come with standard mounting bolts.
Thanks
Randy
Scott
Scott Stiegler
69,618
11,737
W Mont
Thanks
Randy
Hi Randy, can you describe to me what you mean by that.
GoBigParts
4,078
917
Michigan
www.gobigparts.com
Sure, in the 1st picture at the top of the post there is a longer bolt that is used to hold the ski on and the hold the scratcher on. Manufacturer decided to scrap that idea and now he supplies a standard mounting bolt that you can drill a hole to install the scratcher bolt and not used the same bolt which holds the ski on.
Spaarky
3,429
1,345
Chester, SD
Really dumb question. Are you running these in conjunction with the standard rail mount scratchers, or substituting for the rail mounts??
