I have a stock 2018 ski-doo summit 850 SP. In trying to adjust the ramps on the trail I found that the tool ski-doo supplies in the clutch gaurd has a torx end and a phillips end. No allen end. The "pivot" bolt that you loosen to adjust the ramps is an allen head, which I have no tool for on the trail. So I go ahead and give it a go with the torx headed tool and strip it. I order a new pivot, part number 417224221, a 33 mm which is for the high altitude setup on the 2018 models. It comes in the mail and it is longer than the bolt in the sled and also has a torx head. I'm wondering if I have a low altitude setup, as that part number is 417224222 for the 2018, but is the high altitude pivot given for the 2017 models.
