2008 Skidoo XP 154 Part Out
B
May 15, 2008
12
Parting out a 2008 XP 800. The motor I reused and the chassis has been scrapped. Here is the list of parts available for sale:
154" track- I would say 5/10 shape
Gas tank
Complete carbs with choke
Complete skid
Pilot skis- pretty well used
Air intake with sensor
Carb intake box
Indicator support with gauges- Non X package, reads 3xxx miles
Console with the teether
Primary clutch-will need buttons
Secondary clutch w/ jack shaft
Drivers w/shaft
Headlights
Wiring harness
Brake assembly (caliber,hose,lever assembly)
ECM module
Stock pipe
Stock Y pipe
Loaded lower A arms
Steering post
1-upper A arm
KYB shock with stiffest spring (yellow in color)
Matching KYB shock to above with bent rod and shock body scuffing
I also have quite a few other miscellaneous parts that I was keeping as spares like cylinders, cylinder head, magneto assembly, etc... but if someone was in a pinch I could probably help out. If you see something not listed, ask me anyways I may have forgot to list.
As noticed there is no prices, everything is make an offer. Shipping will be extra unless negotiated otherwise. All parts are in Bozeman, MT. Pictures upon request of part
You can PM me, reply to this post, email at vm.blanton@gmail.com, or call 406-600-9799
