F
VIDEO............
FORDpickupman
FORDpickupman
How about some shots on the snow and a few video's would be great ..That is one CCOOOOOLLL sled:face-icon-small-coo:face-icon-small-coo:face-icon-small-coo:face-icon-small-coo:face-icon-small-coo:face-icon-small-coo:face-icon-small-coo
I run the water pump drive belt that is inside the case also used to drive the oil pump, put a pressure switch on the pressure side coolant line hooked to a beeper and a flashing LED, and then put a normally closed trumpeter switch on the cylinder head at or near the gauge wire so when the engine water quits pumping a beeper will sound and then if you miss the light and beeper and the trumpeter gets to high it opens the ground to the ignition and engine quits running. Just an idea.
