Turbo Hood PIAA Light BAr Question?
snowpromod
563
26
Northeast Ohio
Hi,
It looks like I am going to run a turbo hood with the PIAA lights this year! What are the recomendations for the light bar: CR, Alpine, homebuilt, etc. Any pics of your set up would be great - the Alpine looks the simplest but not the strongest. Also, where are you guys relocating your Key and Cig Lighter to?
Mean Yamaha
109
20
Laramie WY
www.Team7220.zxq.net
I have not got my Light bar made yet but I kept the gauges in the same spot and used all the OEM mounting hardwear and it came out sweet! The key is also in the same spot. Used a Dremel tool and it works great. I have it put on my sled now so I will have to get some pic's of it for you. Just been super busy.
snowpromod
563
26
Northeast Ohio
So you will unplug the key and speedo to remove your hood or does the hood fit around the speedo and it stays stationary.
Mean Yamaha
109
20
Laramie WY
No I cut off the locking tabs on both the key and the seedo and they work pretty good. You do have to unplug then but if the hood were to come off the would just unplug themself. I got those pics for you too.
snowpromod
563
26
Northeast Ohio
How is the output compared to the PIAA 1100x's? I was also considering the TrailTech HID SCMR16 - any thoughts on these??
