Installation and Review: Mountain Performance Inc, Stage 1 & 2 Supercharger
5.00 star(s)
T
Tarzannr1
432
153
North in Norway
www.youtube.com
I must say this is some pretty nice work of you Christopher.:first:
Super tread and this i am sure will help a lot of people who will install a supercharger like this.
This is the best documented tread i have ever read on a forum,keep up the good work and have a great ride on that lovely sled of yours.
27,375
I am waiting on a new riser for the handlebars.
Once that arrives, then I will be able to re-install the new handlebars and re-attach all the electronics and get to the START UP PHASE.
W
wilmot
508
101
Clearfield, UT
I finally was able to take my nytro out for the first ride after my MPI S/C stage 1 install. The power is quick and smooth, perfect for my type of riding. The S/C ran flawless. I cant wait for more snow.
M
MTdream
2,548
541
just looked this thread over again, am reminded why I bought my turbo installed from the factory!!!
27,375
Next week I will FINISH the install.
After letting the supercharger sit quietly for a few weeks, we tested the belt tension the other night and determined that I have to remove the short belt tensioner bolt and replace it with the LONG bolt.
Belt deviation is now in excess of spec, so I need to tighten it up a bit, and the short bolt is Maxed Out.
27,375
Delays delays delays.
Tonight the longer tensioner bolt will finally go in.
Might actually have this install FINISHED by the end of the week!
27,375
Under normal conditions I would have just paid someone to do all of this.
But where's the fun in that.
This was a great summer project that kept me near my sled all summer long.
27,375
Belt tensioner has been removed and the longer bolt installed in place of the short one.
Belt tension is now back up to spec.
Waiting on a replacement brass nipple from MPI for the Supercharger Oil Tank, and then its time to add oil, plug in the wires and START THE MOTOR.
27,375
The shorter bolt was fine on mint until the sled SAT FOR A MONTH.
Then when I did the tension test again it failed.
27,375
Right now no.
Long term YES.
My new nipple shipped out from McMaster.
Hopefully it arrives tomorrow and I get to finish the assembly on this.
irondave86
710
342
N.W. Washington
What pulleys are you guys running? I only get a few turns on the short bolt before my belt is tight? I'm running 33/25 but i think im going to see if i can get a 34 bottom pulley and still squeeze the belt on. (if they make a 34 tooth pulley)
W
wilmot
508
101
Clearfield, UT
I have the same setup as chris. The short bolt is all the way in but my belt seems tight enough. I dont want to get it to tight. I can only push my belt about a quarter inch with my finger. But i dont like how the bolt is maxed and i cant tight'n if i need to so i will probably install the longer bolt.
