Yeah, I've heard the older standard probes had quite a bit of lag. But the fast response probes are supposed to be much better.
Heat is your friend when laying the vinyl out. Just make sure you get everything nice and clean. I started in the center of tunnel and slowly worked my way out to the edge. I used a small plastic spreader for laying bondo and smoothed out the vinyl as I went. It really wasnt too bad. Hopefully I will get the boards done this weekend, then I can really start moving on this thing. Once the boards are done I can start working on the skid...
The tether is a "open circuit" normally, which is the same system that is on I believe all M-Series, but not positive. In order for the tether to function properly, I wired it in series with key switch.
The tether needs to be wired in parallel with the key switch so that if either one closes it'll kill the sled. If it's wired in series to close the circuit both switches would have to close.
My father built me a sled lift this spring and I don't know how I worked on sleds for so long without one!!!! They absolutely rock!
