B
:yield:
Hi all,
Been banging my head on this for a while, so.....
I need some help figuring out the instrument cluster wiring on a sled I bought.
It's a 98 MM 700 and only the head light seems to work.
See pics.
None of the instrument light bulbs work, as well as the spedo/RPM/fuel/oil/water/temp gauges don't work either. Underneath, it looks like the spedo cable is physically connected on both ends.
Grip-warmers work!
Are the 2 white connectors and the green connector supposed to be hooked up to something? I see an extra black connector for another headlight, but this is just a single headlight sled.
I have the yamaha manual with the wiring diagram that lists the color codes, but only figured out the ones that are connected (smoothing condenser, headlight, etc).
Another useful diagram that I have been using, but only shows one non-connected end coming from the socket cord assembly (#7).
http://www.partzilla.com/parts/sear...8/MOUNTAIN+MAX+700+-+MM700PB/METER/parts.html
Otherwise, engine/everything else seems just fine, no issues that I can tell.
Any thoughts? Thanks!!!
Hi all,
See pics.
Grip-warmers work!
