Powder lights turbo
C
Oct 31, 2010
30
Terrace bc
I have a powder lights turbo I bought second hand and I am trying to figure out what turbo is on it. I am pretty sure it is a gt 2860 I need to get a seal kit for it and need to know where to get one. I spun a rod bearing now I have a new motor. Also need to know how many head
Gaskets I need when I put in the o ring head spacer from powder lights
Thanks for the help people
yammi4ever
67
Garwin, Iowa
Pretty sure you are right on the turbo and when I did mine Dave had me split the head gasket, use copper seal and sandwich the shim between the two halves
RACINSTATION
7,503
3,459
Idaho
The Powderlites kit should be a GT2860RS "disco potato" turbo. Dave at Powderlites should be able to help you with a center section/rebuild. You just split the gasket and use copper sealant on both sides of both halves to reseal. Neil at Boost-it should be able to help you out as well. On the Eastern side of the country Dave at Hurricane Performance is another good source.
