replacing p.e.r.c. button and grip heater controls.
this1ultraflyz
468
17
18
Saskatoon, Saskquatchland
nice set up for sure Proflow. So you wired the temp, reverse etc. lights is that what they for?
What master brake cyl, bars and riser you go with? and did you change up throtle block?
P
proflow
100
6
18
Buckley, WA
Yep, I also run a mesh hood so its good to have the warning lights where I have them. Also not in those pics, but I no longer have a speedo in my stock hood, (air screen) so I lost those lights from there to.
I cut the stock steering neck & welded the upper half of a Cannondale quad neck to it. That gave me the height without any bolt on risers & gave me a anti-vibe mount. Then a Billet clamp & Fly Taper bars. The master is from a Dale clutch master which is an awesome piece made by Magura w/quick lever adj.
I put my stock throttle block in my mill after pulling the switches out of it & filling it w/epoxy. Then I just carved it as small as possible without either switches.
Proflow
