C
Installed my BMP torsional clutch kit. Came with a red BMP spring for the primary, yellow torsion spring for the sec, dalton 76.5-84 adjustable weights, and TEAM helix.
First, I filled out the form with "M1100T, over 6000 ft, EZ Jacker, Speedwerx can" The paper work that came with it was for a Procross 1100T with a Turbo Dynamics reflash, riding below 6000 ft. WTF? Torsional helix was on the second hole.
Next, the helix was severly pitted (see pics). I called BMP and spoke with Mike. He said all the TEAM helix's are pitted like that. Hmmmm......sounds like BS to me. He also said the setup was correct for my sled. I told him I would install it, but if it sucked ***, I expected him to take it back.
Then, no instructions. WTF? Finally found them on BMP's site.
Drilled out the secondary, installed the spring, put in my wieghts and set them at 83 grams.
Getting the secondary back together sucked, but I finally got it. Set deflections and went out. Pulled like a SOB. Lifted the front end 4 inches off the ground in powder and kept it there.
Went out today to Indian Creek and was riding most of the day around 9000-10000ft. Went up against a modified M8, 2012 Pro, and some other sleds. On climbs, they would get a little over half way and have to turn out, I went all the way to the top and turned out because I ran out of hill. It simply owned the mountain. Even had an audience at one time just watching me scream up chutes and bowls. It was running around 7900 RPMS.
Anyway, the kit is loud and cranky. It is not smooth and it grinds down low in the RPM's. Coming down hill and hitting the gas, it engages very hard. In the low RPM's when one tracking in, or after coming down a hill, it sounds like it is grinding. Soemtimes it also didn't release until I was stopped. Anyone have any idea how to cure the low RPM characteristics of it?
Overall, not worth the $$$$ until I can get it right. Clutch temps were cooler than stock though. Even if I do get it right, lack of support, no instructions and pitted helix would make me think twice about recommending this product.
