If you have a 2012-2015 model Arctic Cat, we highly recommend that you update your drive clutch and driven clutch to the new model with the bearing for automatic belt deflection. This allows you to run the belt deflection very tight, and with the new longer belt your low end will be much smoother and much better performing. It's a night and day difference in low end throttle response and instant power. Great for in the trees, it's amazing how smooth it makes taking off. This design starts your machine out in a much lower ratio, so the low end power to the ground is much stronger and very noticeable.
We take it two steps better than Arctic Cat with our Prolite Jackshaft that is 2 lbs lighter than the oem version. And our kit utilizes our Speed Shop Inc performance Clutch Kit to optimize performance for all applications and elevations. Just let us know what model you have, elevation, and what is done to the motor when you order.
Comes with:
-New 2018 Automatic Belt Deflection Drive Clutch and Driven Clutch
-BDX Prolite jackshaft, 2lbs lighter than stock
-Speed Shop Inc Clutch Kit for your model
-Longer AC Belt
http://www.bd-xtreme.com/index.php?id_product=656&controller=product
Comes with:
-Longer AC Belt
