Anybody do this and how do they like it. What did it do for you?
You can just modify your stock post too. I took mine to a welder down the road and gave him a hand to do it. Charged my 20 bucks to cut out the curved section and weld in a straight piece.
Glad I didnt have to monkey with the airbox. Just put a timbersled intake on instead. I hope it works ok cause my sled worked really well before. Heard mixed reviews on the TS intake.
Cant wait to try my sled out with the new ergos. Im a little worried about the strength of it though?? That bracket isnt that heavy duty. But I guess a guy would have heard about it by now if there were issues.
ya i have tapped the crossmember slightly and the the post slightly all clear there but i dont see how you can melt an inch and a half into the air box
What size stock did you use? and how long of a piece did you weld in? I have repaired posts before by inserting an old wrist pin into the post and welding full circle around the pin and then welding fill to close the gap between the post sections. Never have broken one
It is just slightly smaller than the stock OD, but has a thicker wall. So what we done is cut it to length, then stuck it in the lathe and milled it down the the proper ID to stick into each end. Then welded it up. About half a pound heavier, but super beefy.
If I wasnt broke right now I probably would have just bought the post from C3 though.
Put the 1 inch pipe inside and leave a 1/8 gap in the bar pieces so you get full penetration on your weld. Grind off flush and finish smooth.
