Pulled the chaincase cover off for the first time to inspect everything, and I knew I was in trouble when the threads came with the very bottom 10mm bolt. I was going to try tapping out the threads but it seems very soft in the hole and I'm not sure it'll hold. I was thinking of maybe drilling right through the tunnel and putting a flat head bolt through from the inside and putting a nut on the bolt for the chaincase cover. Anyone know of a reason this wouldn't work? Or maybe someone has a better solution/fix? Sled is a 17' summit G4
Thanks!
Thanks!
