J
Nytro math 101 from last year applied to 1100:
Sea level air pressure is 14.5
1100T / Z1 makes 12 psi at sea level = 177hp
Therefore absolute pressure for this motor is 26.5 psi
Now go up to 7000 ft so air pressure is 10.5psi so to get back to absolute pressure the turbo needs to build 26.5-10.5 or 16 psi = 177hp
From reading the dynotech pages the Z1 turbo put out a max 20psi at sea level making approx 237hp. If the turbo is maxed out at 20psi that means 10.5 + x to make = 26.2 or a sea level equivalent of 15.7psi boost, at dynotech that level of boost with a DD hijacker makes about 210hp.
So sure at sea level the turbo might make enough boost to show 240+ on the dyno but because it has to work way harder to pump up the motor in the thin alpine air 210 sea level hp at 7000ft is about it???
I see an aftermarket for a bigger turbo.
PS I was pretty happy with the power in a 180mcx this winter but it made 180hp at 6psi sea level and about 10 psi at 7000ft if I remember correctly, so 200+ in the 1100 should still be a great sled at 7000ft but man it must have a tiny turbo.
