2008 M 1000 Idle Problem
D
doornenbal
Dec 3, 2007
308
My 08 M1000 only has 50 miles on it but seems to idle really high when warm. When I start it idles at 1700 (normal) after I take it for a ride and come back it holds at about 3200 rpm and take a while (5 mins ) to come back down. This is an issue as my reverse won't kick in above 3000 rpm and as such am stuck without it. Any ideas why ???? there has been a couple of times when mid ride it has gone to normal rpm when stoped but not very often
any help would be great.
R
Nov 29, 2007
89
All three of the ones in my group did this when they were new, I have a couple hundred miles on mine now and it is all better. I would just break it in before i got too excited if i were you.
SaberKitty
1,432
639
Foothills of Grosse Gelb
No break-in mode (My M8 has run WFO at 8100 on the stand and idles perfectly at 1600-1700ish).
For the up/down idle, sounds like a temperature sensor issue either intake air temp or coolant temp. Any modifications or is your M1000 all stock?
gopher-it!
323
75
high idle
150 miles on mine and it seems to be getting worse, will stay at 32oo after a climb for quite some time. annoying as hell. no fix from cat yet but were working on it.
VOHK
150
353
Colorado
www.vohk.com
What altitude are you guys at, I havent experienced that yet. It seems like an issue that would worsen as it breaks in, it may prove even more annoying. Abnormally high idle is typically associated with a lean condition, are you stock? no intake, etc? I am certain that 2 or three points at 3k L on a BD would remedy.
D
doornenbal
Dec 3, 2007
308
My sled is 100% stock no mods i am hoping that it goes away after i run it for 100 miles or so as it is super anoying will be talking to cat here shortly ridding at 2000 ft but spend lots of time in the mountains
D
diggerdown
3,452
677
Deer Park Wi.
Like VOHK said, lean. I'll bet your temp sensor is getting too hot and leaning it down. It will act just like the wrong pilot jet in a carb. I don't know the answer to a fix, but I would bet that is what is going on.
